I need to add a couple of slots mounts to one of my bed rails in my 3rd gen taco. Curious what precautions I need to take when undoing one of the bolts where the GFC attaches to the rail as well as torque spec when re-tightening. I have v2.
Gzila makes aluminum t-nuts that are drop-in so you don’t need to take off the GFC mount. You guys might need something different but just thought I’d throw it out there.
We also make T-nuts that just rotate into place so you do not need to undo that mount. No torque spec though, just good and tight with some blue loctite applied.
I removed the bolt for the same reason and the clamp didnt budge. I installed my slot mounts and just reinstalled the bolt without issues. I tightened as much as I could, didnt really even think about torque specs. Still good and no leaks.
