So I’ve done a search and the options I’ve found don’t match what I’m looking for. Reaching out to close the back door is not the problem. What I’m looking for is a way to latch and unlatch the doors.
I know the rear door has those slides, but you can’t clip the latches closed from the inside. On my leer topper I could twist the handle from the inside to latch the door closed.
It would also be nice to be able to open up the side panels from the inside to engage ‘cabana mode’.
I’m going to keep hunting, but I think the solution is going to be latch replacement.
Move the sliders to open/unlock position. Latch (and lock if you want) the door. Once you are in the truck close the door and position the sliders to lock.
LOL, yeah those ones I get. But you can’t close the latch from the inside, and I’m curious if anyone has a solution for that and opening and closing the side doors.
