I had my friend Patrick 3D print some experimental strap brackets for the GFC well nuts. I wanted a simple, low cost way to get things out of the way and secure. I have the awning poles and a Devos light up and out of the way.
Check out Darkside Overland on Instagram or the web if you want some.
Blockquote I had my friend Patrick 3D print some experimental strap brackets for the GFC well nuts.
Any idea if he is doing other projects, for example:
https://forum.gofastcampers.com/t/courtesy-light-switch-mount-3d-printed-or-print-file-for-topper/33999
I could probably screw around for most of a day on my Orca Slicer program and maybe end up with something that might work, or not…… I am not very good at that process, and I don’t have CAD skills. Should I email him directly? I can’t find his contact info, his website is truly screwed up, I get nothing but garbage on my iPad.
https://www.darksideoverland.com/
Thanks,
John Davies
Spokane WA
Try admin@darksideoverland.com
His Instagram handle is @darkside.overland
He can help you print your ideas…
