This is rad!
I’ve so wanted to try this; but man I’d have to do it when the build out is out for sure. LOL
Thinking about something very similar to use that space, but using some plywood from floor up. I have a bunk built in similar to yours but other side of bed. Good to see yours!
I’d definitely like to see a full height rear panel.
I’ve had this setup before but I had to modify my lower hose to reach as it was originally plumbed directly out of the bed. The splitter is fantastic to add heat to upper and lower levels. If I’m by myself I will usually just leave out a square panel and pump the heat through the bed only. The splitter also helps cut the heat down a little too, the 5kw heaters are really really hot. The electrical is wired through this nice quick plug into the beds aux bus bar that is fed from my Jackery. I need to add a circuit to run my 12v computer fan to keep temps down in the side box while the heat is running.
It’s currently just zipped into the screen on the tent. If anybody has a better option to attach it to the tent, I’m all ears.
Love the setup!! where did you get the hose and splitter?
3Inch Flexible Ducting Hose 16.5 feet Black Aluminum Ducting Dryer Vent Hose with 2 Screw Clamps for Heating Ventilation Air Conditioning (HVAC), Boat Blower, Exhaust Grow Tents https://a.co/d/6fTDfi1
X AUTOHAUX 2pcs Warm Air Vent Outlet 75mm Plastic Ducting Heater Air Vent Outlet for Car Auto Bus RV ATV Amazon.com
X AUTOHAUX 75mm Car Heater Warm 3 Way Air Ducting Pipe Y Shape Outlet Connector Black Plastic https://a.co/d/9bb6UAU
These are all for a 3” 5kw heater. I use the standard worm clamps for the parts that will stay assembled permanently. The hoses that come on and off frequently, I use hand tighten worm clamps. Pretty sure I just bought those at Lowe’s by the RV stuff.
Which heater is that?
VEVOR Diesel Air Heater, 5KW 12V Parking Heater, Mini Truck Heater, Single Outlet Hole, with Black LCD, Remote Control, Fast Heating Diesel Heater, For RV Truck, Boat, Bus, Car Trailer, Motorhomes https://a.co/d/ekW25ZL
Thanks!
@jedgar always has the best products. Man is an absolute genius ![]()
Installed a drawer system into the back of the truck. We were previously using DeWalt toolboxes for all of our gear but it was taking up so much room - this is a game changer. Makes getting in and out of the tent via the bed a lot simpler too.
Drawers are very basic, but awesome (bought them used so they need a paint job).
Built a shelf and picked up some crates from Sidio. The price is a bit steep for a crate but the quality seems good and I like the modular dividers. Storage and organization is essential, especially with the 5’ bed.
Love the esthetic of these boxes.
Plumbed in an RV connect sprayer fitting. I also relocated the power switch for the pump and added a few extra for later. This will be handy to use water outside of the truck.
Added the AluCab fridge slider w/ tilt, mounted to the Deckd/Yakima Tracks (all holes line up, so it’s super easy)… Also finally started the process of pulling each electrical component OUT of the custom wooden box and tucking them into individual cubbies. The USB/120 sockets are now readily accessible from the front corner, standing outside. Next step is disassembly of Deckd system to find hiding spots for as many components as possible. We may use the ammo cans to house things, just depends on space.
How is the quality on those Sidio boxes? I keep seeing them on the inter webs.
Me too lol My ocd likes them more than my wallet though.
