Here we go again! I was unsuccessful at finding any shop in town that would help with these coilovers. I got some pretty unsavoury responses from some of them stating they will no install those for people for this exact reason. That being, needing to take the front end apart in order to make adjustments.
With that I found this on amazon:
ATPEAM Coil Spring Compressor Tool, Heavy Duty Build, Ultra Rugged Coil Spring Compressor Tool Automotive, Strong and Durable Strut Spring Compressor with Safety Guard 2200lb Capacity 11in Jaw Opening
https://a.co/d/0f3Kaghd
I’m happy to report that this spring compress WILL work on Fox 2.0’s. I was able to successfully tear down both sides, adjust and re-assemble the front end in about 4 hours.
The PROCESS
After scouring the internet looking for a reasonably solution that didn’t involve purchasing a floor mount strut spring compressor. I came across the power of these units.
You’ll not the excessive grease on the threads. This is mandatory according to the web of connected computers.
Lucas for the win!
This is my un-marred passenger side and stock set. The bottom of the collar to the bottom of the threads is 2.75” The plan was to attempt to go up 2” as the first adjustment of .5” resulted in .5” height change.
I quickly realized that gaining 2” is likely not going to be possible. I learned that getting the tool onto the lowest and highest coil is extremely difficult. By not being able to do that nicely. You lose quite a bit of compression as the springs outside the tool expand.
Yes I’m in the bite. Those of you that know about these spring systems and these tools know. These things can be terrifying as a failure could result in serious injury! This tool makes me feel significantly more secure. The bar across the top is seemingly crucial. It’s stops the tool from twisting and binding up (which is what happens with the cheapo rental style)
There we go! My finger is where it was originally. I was able to get 1” of adjustment out of the collar. So I am 3.75” from the bottom of the collar to the bottom of the threads. What I expect is going from 5” to 6” ish (or because of how I had the truck parked 4.5” to 5.5”)
The Result
So to my surprise when I went all the way up to 7.25”!!! So potentially too much; but…the key is you have to drive it around to get things to settle.
So that’s what I shall to. It’s a rash to pull the front end apart a bunch to get this sorted. But in the end it’ll be worth it.
I will need an alignment and am hopeful that the wd40 I’ve been putting on those nuts/plates loosens things off ![]()
My son asked me right after this photo ‘Dad, why did you decide to make your truck like this?’
