2020 Ford Ranger Lariat Supercab GFC with Solar Panel Wind Fairing, Expedition One Bumpers, and Victron/Battleborn energy system
Expedition One Bumpers , Comeup Winch, and rock rails, installed by BuiltEast
sPOD, arb compressor, arb rear diff air lock also installed by BuiltEast
I installed the following
Victron and Battleborn energy system (12volt 200amp hours with 2000 watt Victron Inverter) per ExploristLife instructions, click here
LightLeaf solar panel wind fairing
youtuber Pask Makes drawers using roller skate bearings and 1" square tubing, video here
I’ve documented my project on my blog and tons of photos are here [updated links to my new blog aug 2025]
here are some highlight photos of the exterior
Victron/Battleborn photos
And finally, the truck bed build photos
Oh and on my last trip I used a Geyser Sponge Shower, Joolca single shower tent, a Planar 2d portable diesel heater to keep the shower tent warm in 50 F degree weather. I also use a $30 electric kettle to get the 1 liter boiling water the Geyser shower needs.
holy over board setup. that’s 1 way to level a Ranger. I just lifted the front 1"
have you upgraded leafs springs?
Is the solar panel supported from underneath?
do you a parts list for the thule rack? I get lost trying to figure that out mess
That’s actually one of our panels! They are made out of a carbon fibre foam core construction, so they are completely rigid and self supporting.
I made the frame for the solar panel out of 2020 parts. There’s a detailed slideshow here. I used red locktite too. It’s held up great. and yeah…suspension upgrades are coming :laughing: she’s a bit low now.
The Thule parts I got from rackattack. I just redid what I picked for my truck for you. Rackattack fit your vehicle
I went with the Thule Evo Clamp system and windscreen. I’ve been getting 18.5-20mpg on the highway, so I think the Thule windscreen and solar panel definitely help.
inspired by your “wind fairing” …what made you choose the Lightleaf solar panel over it’s competitors ?
I think for me it was that they’re used on a lot of tear drop campers. Right on the front. So I figured if they can stand up to that kind of abuse, it would hold up as a wind fairing, which it has so far (touch wood). I liked the slight arch in their gleaf panel, this one. And that the corners are designed with rubber grommets for bolts. The solar cell performance is pretty good too.
I didn’t want a flexible panel because I’d have to make a backer myself and glue the flexible panel to it, and I’ve seen a bunch of youtubers having to replace their flexible solar after a few years and then struggle to peel them up. I think with flexible panels they tend to not last as long and their efficiency isn’t as high, but they are improving. I’ve seen other carbon fiber composite backed panels, but the other ones I saw were more for sailing.
Adding some more photos of the solar panel wind fairing build, to save the click to my website. Parts are listed further up on this thread.
Last two key photos. to get the pivot hinge part on the end of the 2020 tubing, I tapped some threads. I’d never done that part before, but tapping in Aluminum is very easy and you can get a cheap thread tapper kit off Amazon.
Thanks.
You’re right regarding efficiency. I’ve been looking at flexible options , i.e this long , thin one:
but efficency is only 11% compared to the gLeaf which at 22% is double!
Excellent catch @pigneguy ! Love reading stuff like this in the forums so we’re helping others figure stuff like this out. And thanks for sharing that link, I hadn’t seen that online store before. Love window shopping new sites! New to me anyway.
agreed, always good to be part of a knowledge based community…especially in these politically divisive times.
The new panels are actually 25.1% efficient! Also significantly more durable than flexible panels. Let me know if you have any other questions.
thanks for the info Nathan
Awesome Build! Well thought out and I love the attention to detail… I also went with 2-100AH Battle Born Batteries and am happy I went with that much battery storage. You cannot go wrong with Victron Components too!
Thanks @Enduro_Woods_Rider!
I replaced the rear GFC panel’s led light strips this week. I’d used interior led strips ($20 for a 4 pack), but water must have gotten inside, ruining them.
I replaced them with this motorcycle light kit, only ~$42 on Amazon, click here Being able to change the color is awesome, also has dimmers in the remote.
The new led light strips are weatherproof, but the wire connections don’t seem that robust, so I used 1/2" heat shrink over each connection, which should keep the water out and also help keep the connections together. Before using the heat gun, make sure you test the lights first. Also the heat gun is great for making sure the adhesive mounts stick, when it’s cold out.
the old lights that failed
