A Cajun’s build… “Odys”
Makes a difference in what way? insulation? thx!
a little insulation and a more homey feeling, if that makes sense
Finished the panels with the carpet, looks so much better. I may do the undersides if I’m able to buy individual panels. I dont want to buy a whole box just for a couple of panels, its pricey.
Condensation and heat also
Any chance you have the outer dimensions of both the drawer and shelf? Such an amazing build.
I dont know if this will help at all, but the drawer is 14" high and almost 21.5" wide and 48" long. As far as the shelf, its fits perfectly between the wheel wells, and the drawer/back wall of the bed. And its the same height as the drawer, but the top surface board sits right above. I don’t have the exact measurements, I tossed that piece of paper a while back.
where did you source the 24" carpet tiles?
Lowes
Hey, this is a great looking build. I have the same front molle panel and just got a water heater for that same location. What did you use to mount it? Thx!
I drilled 2 holes in the panel itself and used some bolts
Really well, organized, brilliant build. I love it all. I had the Ironman water tank with that same pump in my rig. I have since switched up my set up. The one issue I had with the permanent tank was cleaning it. How do you clean yours and the hose? I never had a great solution. But maybe you might.
I have a filter that I attach to the water hose to fill up, and some drops I got off of amazon to treat the water to keep algae from growing. When I dont need the water, I keep the tank empty. Havent had any issues yet.
I love your build. I happen to cut a small slit in the tent near the gas strut. Filing the corners was a no brainer after that.
Clean install can we see more on this
