I’d still like to see the new light kits GFC is going to be putting in the camper as well as the passenger side tent door!
I’d love to see some t-bolts as an option - you could go an even larger diameter with them. I haven’t found any commercial t-bolts that fit yet.
You go fast enough in the dirt, things tend to change positions. The dog bones are helpful by giving a larger mating surface, but with other accessories you just have the bolt that holds it down and the bolt will be subject to greater forces. You start putting things like a waterport up there bad things may happen.
The dog bones are necessary because the 1/4 T-nuts protrude beyond the extrusion (unlike the -10 ones that sit flush); if you tried bolting directly to them, the T-nut would slide around. The dog bones ensure the clamping force of the bolts is transferred to the extrusion.
