Help removing camper topper
Hi everyone - I’ve emailed GFC support, but realized I might not hear from them before I need to with the holiday and all. Maybe someone here has the answers I need.
The body shop says they need to remove my camper to do the work that is supposed to start this week. Is the bolt marked X in the photo the only one that needs to be unfastened to lift the camper off the truck? I don’t have to remove the entire upper/lower clamp, right?
If that is correct, does anyone know the proper torque to reinstall?
Thanks for any help anyone might be able to provide.
-Ben
In simple terms, yes.
Torque spec: tight enough :crazy_face:
scary ain’t it? 4 bolts holding everything together with a torque spec of crank it down as tight as you can
When they installed mine a couple weeks ago, I am pretty sure they said 20 lbs of torque.
There is an actual torque spec in the official manual, I don’t remember what it is at the top of my head but I thought it was in the 40s.
That’s what I remembered, too. And you’re right. It’s in the GFC official owners manual, and it’s in the 40s:
Torque
40 and retorque occasionally
What bit did you use to remove this screw? I keep striking out, size 7 hex bit too small, size 8 too big
It’s an SAE size hex. I can’t recall which size. For some reason, GFC uses SAE hardware rather than Metric but just about every truck uses metric bolts
Because MERICA!
do you have to loosen the allen fitting on the side of the clamp before you do the big bolt in the middle. i think 8mm fits the big hole on mine? seems like SAE for the allen screws on the side of the clamp. weird. no return calls from go fast…yet
