Solar Update:
As mentioned earlier in the thread, I pulled the trigger on the Lensun.
It arrived this morning and I played around a bit and took some photos and decided to give my first thoughts.
- This version seems to be their “universal” 85w panel.
It would have been nice if it was cut/ designed to fill the full hood scoop/void
- This does not have the metal eyelets like some mentioned/were concerned about
- No Adhesive is provided. I have some 3M tape from other projects so I should be okay but that goes into my major gripe:
Do not buy the vinyl they offer.
It came folded, even after letting it soften up in the sun most of the day it still had a crazy crease that stayed even after application and squeegee process.
For unclear reasons, the precut vinyl that is the same size of the panel came folded
(the panel was shipped and boxed flat)
I’m not a pro but I also have done this enough to know how to prep and apply, and holy shit it looks like dog water.
As mentioned it came with no actual adhesive so I mocked it up with painters tape.
I think it will look okay and it covers the line fine, but, even after being applied and undisturbed for about 6 hours, the vinyl came up with the painters tape!
Will likely just find a local shop to wrap my whole hood and use VHB on that.
The hood opens and closes no issue, the panel is pretty light weight
I didn’t notice any straining or audible struggling from the motors/struts when cycling
I was giving the vinyl as much time to succeed before a very rough test so by the time I got around to testing the panel itself I didn’t have good sunlight (very close to sunset), I plugged the panel into a power station to verify and it works as expected.
Next up I have to make cables to go between the charge controller and the batteries themselves.
The panel comes with mc4 connectors, I opted to not buy the cheap charge controller they had as a bundle option as I needed to use a dual output charge controller to connect to both 12v batteries on the truck
Here’s the main portion of the “wiring harness” that I made this evening:
I always throw a circuit breaker on the + leg of my solar, just in case Helios throws a fireball right at my panel.
I somehow ended up with an uneven number of mc4 pins and plastic bits
and alas, nobody I know of sells connectors in person.
So I’ll be waiting on Amazon to send me a new pack so I can make a short pigtail and wire the panel in to the controller.
Stay tuned, once I get my GFC I will be throwing 600-800 watts of panels on the roof of the camper
(still playing Tetris with panels)
