Wait what? You have an IG account?
heh yeah. Not a big fan of social media, but with GFC using it so much I felt I needed to
https://www.instagram.com/joshedgardesign/
I agree! If used wisely for a certain purpose I like the potential however my dog and truck have become folk legends!
I think I am down to the final prototype. I think it isnât too bad visually and works well so far, but have yet to test other than pouring water on the camper top. I have it attached by snapping into place and a small piece of double stick tape. Holds solid on the highway at 80mph, and is so light I canât imagine it will move around off road at all. Going to test this one for a little while to see how it holds up off-road and cross winds etc.
@jedgar Are you also testing on a Tacoma?
Not yet. Once I am happy with this Iâll get it tested on Tacoma and Tundra. The only variable should be how far in from the edge of the camper the factory drip rail is.
This looks really good. Itâs amazing what one can do with a 3D printer. If you can see it in your mind, you can design it and print it. Great job again.
For me, icicles will form in that spot as snow melts and refreezes. I wonder how these things will do in freezing and thawing cycles after a snowâŚ
I had a piece of paracord connected bewteen the two holes that the hatchlatches mount through. I reused this and just looped it around the end of the latches. Whe the door is shut the paracord rest on the nuts for the slide portion of the latches. It holds the latches open nicely without having to adjust them tighter.
Made my own step up, inspired by you. If you can weld, I threw this together in about 5 minutes from a couple metal scraps I had laying around.
Thanks for the idea!
Nice! Looks good. They make it way easier!
Smells like copyright infringement up in hereâŚ
Awesome thanks for sharing the pic!
great picâŚalmost missed the pups, snug as bugs in a rug.
does anybody have a good system for charging multiple remojis at the same time? right now, I just plug in all before I leave home and then top off a single at a time while driving.
I know someone with a Tacoma that lives where it rains A LOT - that would be willing to test a pair.
This is a really cool idea.
I have usb-c in the truck so I have a hub that gives me 4 USB ports to charge them all at once.
Sign me up when it becomes availableâŚthat dripping drives me crazy!
I think I will tie mine, too. I liked having them last weekend, but one âdriftedâ into lock mode while driving. Easy enough to unlock from the side, but tieing them open will work, too.
Love the step! Have to install the Mag holders next.
Thanks, Josh!
Awesome thanks for the feedback! I run mine quite tight so they canât move but wanted them loose enough for everyone to be able to use including kids etc.
