Has anyone actually had any issues with their Prinsu rack coming in contact with their GFC Camper? I’ve seen discussion on the forum about this happening but I’ve also seen people commenting on their full-size prinsu working just fine without issues.
Will I have to cut? Can I leave it on during install? General thoughts?
No worries man! It looks like some people have had luck fitting it underneath with third gens as the camper sits a bit higher than on second gens.
It looks like the clearance is tight (3/4" seems tight to me) and its important to keep in mind that your truck bed will flex a bit off road so YMMV depending on the type of conditions you take the truck in. Though it looks like @Robjob is in the same boat and hasn’t had any issues.
Yep your intended use will make a difference. I wouldn’t recommend rock crawling with my setup. I’m more of a camper than a 4wheeler. But if it ever hits hard the prinsu or the cab is going to get the damage. The GFC is a tank
I have a 2017 double cab long bed with the V1. My Prinsu would hit often when the bed was flexing and when I was driving fast hit a bump or a wash. I trimmed my down with a cut blade on a Grinder. It worked out great. The V2 is apparently lower than the V1.
