RIGd Supply Products
Hi Chris,
Quick question. What do you recommend I lubricate the ultralatch with? I was wondering why it was so hard to open and close and someone recommended greasing it with the same thing I would use on bearings. I used a garage door lubricant and it is worlds easier to close now. Is there something better I should be using? Thanks for any help.
Yes- that’s the point I’m trying to make…Hooking up to the stock hitch. No shaking. It’s the swingate that shakes (not the Pivot).
@r_duchene, my spare tire on a swingout moves around a bit and it’s only ā‰ˆ75lbs and mounted in tight to the swingout. I couldn’t imaging the extra movement with 130+lbs hanging out so far on a huge lever like that.
Hey there!
You can use Tri-Flow lubricant. It is mess free and will keep your latch operating smoothly.
