I have compiled a parts list for house battery using a LiFEPO4. This consists of everything you’ll need.
Dual Battery - LiFEPO4.pdf
IF you’re using “solar generator” then just swap the LiFEPO4 to solar generator (in my case, a Delta 2) and add XT-60i cable from the DC-DC charger or from the solar panels (if using solar only, then just use XT-60i cable and skip the DC-DC charger (with or without MPPT))
