Also if you have a Tacoma I’m pretty sure the bed plug will not charge the delta 2
Skip to 5:30
2500 Ram. I have a 400w plug in the bed, so it will be slower than the wall. I’m now curious to see if it works at all. I am really impressed with how quickly it charged though.
@ws6616 I am waiting to hear back on my Blue Sea contact form, but the middle-term plan is to get everything set for alternator charging of the ecoflow as well as all the logistics for the batteries in the bed w/o batteries.
check the amperage rating for that plug. ecoflow may be drawing too much for the plug to handle
3.5 is not going to cut it. This trip will provide plenty of charging opportunities, but now I have a good reason to prioritize that Blue Sea order.
Ram sells it as being able to power tools. I always assumed I could plug a circular saw in or something. Looks like it is a poorly placed laptop charger.
yeah… lol maybe when the truck is in park vs when the truck is in drive?
i know my 4runner was able to charge my jackery via 110v when in park but not when in drive
I have had both. The solar to battery setup with enough solar and battery bank is great if you have a truck in which you can leave it in the bed or inside all the time. In many cases, GFC owners (myself included" use the camper as a truck more often than the camper, so I like the portability of other options. A local company, Craft Auto Works, makes a truck/overland battery box that is meant to be wired to the alternator and pulled at any time. It’s called the OES Pro. I have had it for about a year and it’s basically a nice battery and charging component setup in a stand alone box without proprietary parts. I love it. On any trip we take, we typically drive at least 3hr a day, which will charge the battery to full with a fridge on 24/7 and charging phone.
Different strokes for different folks, but I prefer that box because it works functionally similar to a van style electrical setup, but is portable and removable.
I’ve run both setups. The all-in-one solar generator (I use an OUPES 1800 now) is awesome for simplicity. I use it to run a fridge, charge my laptop and power lights. I even used it at home during a storm outage. For simplicity and reliability, it’s hard to beat.
I have compiled a parts list for house battery using a LiFEPO4. This consists of everything you’ll need.
Dual Battery - LiFEPO4.pdf
IF you’re using “solar generator” then just swap the LiFEPO4 to solar generator (in my case, a Delta 2) and add XT-60i cable from the DC-DC charger or from the solar panels (if using solar only, then just use XT-60i cable and skip the DC-DC charger (with or without MPPT))
Damn, this is nicely done. Pics, concise descriptions/reasons for component choices, and recent pricing. Thanks for putting in the work.
thank you sir.
i compiled that for a friend a while back and put that in my cloud drive and then i remembered about this thread hahaha
Dropping a link to the West Mountain Epic PWRgate. This thing is inexpensive, small, handles solar and DC inputs, switching between them, and a bunch of different battery chemistries. It’s been jammed in a small battery box in the back of my truck for 3 or 4 years (summer only) running a fridge 24x7 with just a single 100w solar panel and 50Ah LiFEPO4 battery.
https://www.westmountainradio.com/product_info.php?products_id=epic-pwrgate
Hey man, sounds like a killer summer plan!
I was in the same spot recently — debated DIY vs solar generator. I ended up going with a portable unit (like a Yeti-style one) just for the simplicity. Didn’t wanna mess with wiring while trying to get my rig ready.
The main difference is:
- DIY = cheaper + more flexible, but more work
- Solar generator = plug-and-play, but costs more per watt
Before I chose, I used this calculator to figure out how much power I actually needed based on my devices (fan, fridge, laptop, etc.):
Helped me avoid overbuying. Hope it helps!
I got this 400 W anytime to charge my Jackery 1000 while driving . Installed, plugged it in to charge, start driving and turned it on. hey 236 W, down to 76, 76, 34, zero. Sit there for a minute or two back 76, back to zero.
Finally installed 200w solar panel. Have both plugged in. Solar great! Start driving, turn on the inverter and consistently holds 230-250w. I don’t know what changed, but I’ll take it
