Here a few upgrades I’ve made
Install EcoFlow alternator charger
Install flat marine, solar panels 400 W
Look no more grooves no more bugs, rubber panel
Using diffused rock lights for scene lighting
Grab handles on the cheap
Etc.
Nice job. Where did you get the diffused rock lights? Cheers.
And how did you run the wiring?
Drilled into the panel , ran wire on adhesive chips into plastic sleeves finished with clear silicon.Solar panels are mounted with adhesive compound by manufacturer.
Eco flow went easily through the lower truck bed caps then ran the large cable down the top of the frame to the battery bay. Easy plug and play
I did all of this a year ago no failures no leaking each panel produces 200 W
Between the panels and the EcoFlow charger on the alternator, I have all the power I need
I installed the EcoFlow Alternator Charger and went a little overboard about how impressed I was that EcoFlow released the new Alternator Charger.
Review
“Drilling hole and rubber grommet for solar panel wiring?”
Have you got your Delta2 cold enough to shut down?
