Any cheaper options out there?
@GFCnortheast there are these Aftermarket products for the GFC - #41 by d.shaw
also search for DYI on here
Posted in another thread, but here was my beef bar alternative:
- (x1) 10 Series 1" x 2" Extrusion (don’t recall the length). Bar ends tapped for 1/4".
- (x2) 6 hole end plate
- (x4) Stainless 1/4" bolts and washers
- (x4) GFC T-Nuts (1/4")
- (x1) Prinsu Maxtrax Mount
Things to note:
- Get access holes pre-drilled. Allows for easier accessory install (don’t have to mount and dismount), and it allows for any water build up to be drained.
- Use stainless hardware
- Use 1/4 GFC tnuts, not 10/32.
where’d you get these? that’s precisely what i’m looking for!
thanks!
-Chuck
8020.net not to step on your toes @fatfurious2
If you’re in Canada, RMMC.net I think.
I ordered from 8020.net. You can also get some stuff a little cheaper from tnutz.com. I got the gfc nuts from gzila. Took about 4 weeks for delivery. I used this as my build sheet:
I zoomed in on your end plates (6 hole). Where did you get those?
I purchased them from tnutz
Nice job. Mind sharing how you attached the bar to the plate? Thanks so much
The gfn nuts mount the angle to the camper. The bolts and flat nuts mount the angle to the bottom or top of the aluminum bar, the flat nuts go inside the aluminum
