Coastal - 2019 Tacoma Build
Appreciate it, @Buhlockaye…if you have any pics, that would be awesome! :metal:
@Tailhook.Actual check out This thread. I added some photos but if you need more, shoot me a dm and I’d be happy to discuss further! Goes for anyone who sees this hahaha.
@Tailhook.Actual Yes, the wiring then enters into your camper and you can connect to power however you would like from there. @Buhlockaye sent me some photos before I installed my lights that were super helpful. I however, forgot to take photos of where it enters into the camper :expressionless:
Outstanding…thanks, guys!
Overnighter:
No real build updates, very happy with the set-up as is. I did try out adding an old Thermarest inflatable sleeping pad underneath the cushions and seemed to sleep much better. Will likely be using it from now on.
Interior Lighting (Update):
The LED connectors eventually failed due to the repeated movement from opening and closing the back GFC panel. This created a bend/stress point for the wiring/connector/LED strip. To solve this I cut the back panel LED strip off and attached a new strip to the top circular bar of the camper. This way the LEDs don’t move when opening or closing any part of the camper. For good measure I soldered them and added a good amount of VHB tape. Seems much more solid now!
Recent Adds:
Took the truck in for the 60k mileage service at a Toyota dealership and also had the spark plugs and differential/transfer case oil replaced. When I picked up the truck I noticed it felt loose and had a bad shake at highway speeds so I took it back in to find out that they forgot to torque down one of the wheels. The dealership ended up owning their mistake and offered a few things to right the wrong. I wasn’t planning to upgrade my wheels anytime soon, but now have a fresh set of Method wheels on the truck. Lesson learned to always check other peoples work…
I later added in the OEM Tailgate Lock and its a world of a difference. Now the truck fully locks up keeping the truck bed contents safe and I don’t have to manually lock the tailgate when getting in the tent to camp. Very straight forward install as well!
That’s a nice upgrade! Thankfully nothing bad happened. IMO the remote tailgate is the best upgrade bang for your buck.
Truck Bed Shelf:
Very small but useful addition to the truck bed. Made with scrap wood and designed to fit in the existing Tacoma wheel well slots. The shelf is easy to remove when needing to haul larger items in the bed as well. The concept was to keep the full bed length accessible for surfboards, but allow for elevated storage (i.e. duffle bags) to maximize space and ease of access. This also allows you to store gear on the shelf and utilize the truck bed for changing/hanging/going in and out of the tent. Overall works great, very simple, and essentially no-cost.
Updates (None!):
2024 was a busy year where other priorities took over camp trips, but I was still able to fit a few in. Highlights were a week long trip in Death Valley and an Anza Borrego weekend trip. I haven’t made any changes to the GFC, which is great to see that all thats mentioned above has held together great (lights, bags, shelf, etc.)!
A few things are in the works for 2025 including some rear frame bags, more to come!
I’m interested in routing the wiring for a backup camera and exterior lights inside the extrusion as you did for your chase lights. Do you have any other pics showing removal of the lower tracks on the sides or back and/ or how you routed the wires?
On my V2 Pro I’ve removed the three screws holding the lower track on the back but it’s not coming off easily. The ends are loose but it acts like it’s fastened or glued in the middle and I don’t want to force it?
Thank you.
It has been a while since I did this, but I beleive you just unscrew all the screws and pop them off. Granted this was on a V2, not a V2 Pro so things may have changed!
Heres a link to the thread and video for the new tent replacement, could be useful but still not a V2 Pro - V2 Pro Tent Replacement - #11 by Reggie
Thanks, the video is a big help. Cheers.
