The lights are the Matt Gecko LED light kit he sells for GFC campers. The box is a drawer I built for my fridge but is currently being re-worked since my storage needs have changed. The bed mat is just a BedRug fit for my truck bed, not up the sides. Hope that answers your questions, let me know if you have any more.
Thank you! Do you have other photos of the box? Iâm looking to see if anyone makes a storage solution like that, that integrated with the wheel well, and yet looks comfortable to sit on, but I havenât found anything yet.
@2ayne great call on this. I just went on my first trip with it installed and itâs amazing how much more room I have in the cab with all the little doodads in the curtain instead of jammed in random pockets.
Now I just need to figure out a good way to label the pockets so I donât spend time searching.
These just came back in stock. Ordered mine today!
Just saw it pop up in my feed too. Iâll be purchasing also. This fit a standard camper just fine correct?
Yes they fit perfectly for both the standard and XL
I purchased one of these last time they became available and wound up never using it. Never even opened the box. Just went a different route with my build.
Iâd be willing to knock a bit off the price, as long as the buyer pays shipping. Anyone interested?
The pole to keep the top of the curtain straight is about 2â too wide for a Tacoma camper, I had to cut a bit off to close my side doors
Whatâs that water tank looking thing you got there?!
Sweet, thanks!
Assuming youâre happy w it?
Been looking at the Yakima Roadshower for a bit too.
I like mine. Mine is installed on the side like @WVTRDPro. He has a much slicker build than I - but mounts his waterport the same way.
Do you still have it any want to sell it?
Finally installed a Duluth in my V2. No place to hang it on the V2 so I installed grommets on the Duluth using a cheap amazon kit. Works great! V2 mounting points seem legit; only hand tighten the bolts though.
What size grommet should I order to fit the GFC mounting points? Iâm getting ready to pick up my camper and love this mod. TIA
I ordered the kit linked below. The kit comes with two grommet sizes; I used the smaller (3/8) size. Works perfectly with the V2 OEM mounting point hardware. The cutting bit in the kit works great, I used painters tape for hole placement markings and protection when cutting. I also used a block of wood instead of the little âwood chipâ included in the kit. Only took like 10mins to install and has performed flawlessly filled with camping stuff. The hardest part is holding up the organizer and marking the hole locations.
General Tools 81264 Multi Grommet⌠https://www.amazon.com/dp/B01BH4FLCE?ref=ppx_pop_mob_ap_share
Thanks so much and clever use of the mounting points!
What have you all ended up storing in the long middle pocket? I havenât found a real usefulness for its shape yet.
I used it for my rain fly poles and 4-piece fly rod mostly, but also have stored shotguns and even raw steel sections.
I have camp chairs and camp pillows in there and its awesome
