Lights in your GFC?
Nokero lights are pretty cool too.
I’m loving the cairn xl from Lander. As recommended by someone else on the forum.
I stuck a magnet mount on the lamp and some metal plates that I glued in a few spots in the camper. Super easy to just move the lantern from spot to spot in the camper or outside.
Is it flashy or super cool? No, but a lot cheaper than many other options
@Camper1088 yeah to be honest i usually use my head lamp and only occasionally use a mpowerd solar lamp, i find they are useful and easy to throw on the windshield to charge…
I’m also ok with a headlamp and little magnetic rechargeable, but I clicked through to that website and got an add for 40% off for black friday. If you needed an extra kick.
I just bought a 3 pack of the luminoodle click and have one in camper and one on the back panel. Cheap and work great
Danny, I installed the Matt Gecko kit on my own. I’m not fast, so I dedicated a Saturday to it. I have not noticed any issues with wiring it to my battery, but I think it is a good idea to have some sort of fuse block…I just went with the inline fuse Matt supplied. No dimmer for me–either they’re on or I’m going to sleep. For me, I will work on my home electrical, but I always hire a plumber.
Installed Matt’s lighting package as well. Initially I installed as he described, pretty easy, just take your time and don’t over think it. We novices are too concerned with blowing up our rig when we add a new floor matt! (I know I do anyway).
I later modified the top install by soldering his two leads together up front and only run a single cable back to a touch dimmer. I went with the touch dimmer b/c I like the blue ring of light for nighttime access.
On the bottom is was a stock install with the exception of the dimmer I installed. I used the rotary dimmer as I wanted something a bit beefier for when I have gloves on hunting.
Looks sweet! I’m using mine less in the winter. Might update this in the spring.
Happy New Year!
@Hampnterri what did you use to tuck away the wires for the S2 as a chase light?
Used cable ties, commercial cable wrap mesh heat shrink cable wrap, iadhesive zip ties - all available at a commercial electric distributor and probably most hardware stores. There are probably more elegant solutions, but this is working and wearing great so far…
Awesome thank you that helps on the adhesive zip tie base, that’s pretty clean actually and good to know.
We ended up doing a set of three of these in the truck bed - easy to charge every one in a while with USB, and the remote and a red option is nice.
https://www.amazon.com/gp/product/B083LJM55C/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Then we did one of these with a magnet mounting option in the top of the tent, and it holds well to the frame in the GFC truck bed when the top is closed:
https://www.amazon.com/gp/product/B07VBHN8M6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
We decided that running power for lights didn’t balance with our desires to keep the Gladiator and GFC simple, after having a campervan that was home like, this truck was never going to compete, so why try :wink:
Love this. I’m also looking to connect LED strips directly to a fuse block like you did. Most of the LED strips I see online have a AC wall plug or a 12v cigarette lighter adapter. Did you just snip that off and wire it directly to your fuse block? Or but lights that were meant to be direct-wired? And do you have a link?
Hey all,
I am going to order Matt Gecko’s LED kit for my Tundra. Seems simple and a product that a lot of people are stoked on. Its not super critical but does anyone have any experience adding a dimmer switch to Matt’s light system? I’m sure there’s a youtube video out there explaining it somewhere but figured I’d start with the forum first.
Thanks in advance!
Can you show a more detailed photo(s) on how you ran the wiring for the external Scene Light you have mounted on the extrusion? Thanks, any suggestions on doing a similar external light?
Where did you get that cargo net? Thanks
@reesespieces It was just some net I found on Amazon. I have since upgraded to a custom fit VRNCLR Sewn Storage bedding storage since I was unhappy with how much the Amazon net sagged.
I purchased these dimmable, rechargable motion sensing lights on amazon. They are super cheap and work great. I saw them recommended by multiple users on this thread. They come in a 2 pack, I bought 4 and I put one on each panel and have a spare, see pics. They work well for me but they are another thing to charge. I travel with a Jackery 500 that’s constantly charging off the Tacoma bed outlet, so not an issue.
For the upstairs camper I purchased these waterproof, USB powered LED lights that came with 3M tape backing. They fit perfectly in the recessed track inside the camper (shown here). I hooked them up to this USB dimmer, which I’d also highly recommend. I power them with a small USB battery stick.
I recently installed these black diamond remoji lights with the magspots from @jedgar. I really like the lights and so far they have been holding on well to the mag spots. I thought that maybe the magnets wouldn’t be strong enough but I have been doing some off-roading and so far they have not fell off.
http://jedf.us/#!/GFC-MagSpots/p/292809060/category=113909263
I definitely wouldn’t encourage folks to leave the lights on when driving, but I often left mine on and they stayed put shockingly well.
