Check out the latest new product updates on Instagram at @ruff_road_designs
I also have MOLLE panels for behind the rear seats of the Toyota Tacoma.
V1 GFC owners: The V1 GFC only has 4 mounting points (V2 has 6) therefore the panel may need to be secured to the frame at additional points to prevent rattling. I recommend a Quick Fist clamp around the diagonal cross member. Zip ties and/or stick on foam trim from the hardware store work as well.
I haven’t had a chance to measure a Jeep gladiator in person yet, I’ll send you a PM as it’s possible the Gladiator is the same dimensions as another existing panel.
I am slowly working through the form responses and sending follow up PMs to get shipping qoutes.
Been a crazy week at work but if you haven’t received a PM yet don’t worry it’s on the way soon.
The panels are intended to hold things like recovery straps, shackles, shovel, axe…ect.
I don’t know an exact weight limit as it will vary alot by how items are attached to the panel.
For example a 15lb item mounted with only 1 hole of the MOLLE grid will be a bad idea.
A 15lb item with 4 mounting points 10"+ apart would be totally acceptable.
For additional weight capacity I recommend adding 2 “Quick Fist Minis” to attach the panel to the 2 diagonal frame members of the GFC.
