Thanks for the kind words guys! Ive got this designed to work with GFC molle if someone wants to test for me?
additionally my Howl R1 mount too if someone was interested in testing that too.
Id be happy to give you a full review on anything you make bud
You got a howl R1 and a dometic water dispenser?
I have an R1, been looking at getting a water dispenser, this will be the justification I suppose
I have an R1 and am willing to test it out. Lemme know!
Update: installed the jug today and the standard hose is long enough if you position everything correctly. Hose just kind of hangs there and doesn’t get caught in the slide.
Im down to test for you
How has it worked for you?
I only mounted it from the top, it hangs, no side or rear mounting.
Setup a mounting bracket for the ladder on the inside wall of my Wrangler.
I used two different size “Quick First” clamps connected to the frame of the Rhino-Rack Backbone. Two 3” Quick Fists hold the feet at the back of the Jeep, and one 1" - 2-1/4" diameter Quick First holds the top of the ladder. Round out the supplies with a trip to Ace for some hardware. Drilling out the holes was tricky with a piece of scrap wood behind to make sure I didn’t hit the fiberglass top.
I ended up relocating the front Quick First so that the mantis claw would hold it ladder up from slipping down and rubbing/rattling on the fiberglass.
made this to add on to my truck!
also trying to figure out a way to add more space for patches in the GFC… i’m running out of space in the cab LOL
A velcro patch with glow in the dark outline of my truck with GFC on it. Had to omit some details for quality.
I added Velcro (loop side) to the bottom of my panels and stick my patches there. The headliner in the Colorado sucks for patches.
that is a very good idea!
the headliner in the Ram is impossible for patches lol
how did you attach it to the floor panel? the roll I got does not have adhesive in the back and fabric glue seem like a bit too extreme.
I bought adhesive backed 3" wide loop from hookandloop.com. I bought white so it would blend in. I’m getting to the point where I’m going to need to add more loop to the two squares :rofl:
ah the one i got has no adhesive because I had to convert iron-on ones i got from various national parks , and those adhesive won’t work.
looks like i gotta buy rolls of loop with adhesive then
Changed the top
Woah… That’s wild! What did you use? I like your headliner!
What in the actual? I can’t figure out what I’m seeing here
I put two big holes and then two windows in my camper. :face_with_peeking_eye:
