What mount is that for the WB camera? Looking to do that same WB G900 setup for my GFC that will be installed in August.
It’s custom, I designed, printed it and made my own T-nuts. Could make you one. It’s for the WDR camera.
Where did you get that slide and cable pass? Looks like a goose gear slide but I cant tell.
Finished my secondary battery setup for unlimited party mode
Video:
Backing plate is self-fabricated mounted to the bed rail using blue sea bus bar and fuse blocks, Renogy 50A DC-DC charger with MPPT, and a Li Times 100A LiFEPO4 housed in a all-top battery box tied down using Front Runner Stratchits.
The camper battery will be used for camper lighting (upstairs and downstairs) as well as diesel heater in the winter. I may or may not add an inverter to run EcoFlow Wave 1 in summer or to power the laptop when I’m just hanging out inside the GFC.
How is this working out for you?
More electrical work. Maybe someday I can start adding “cool” things to my GFC above the basic necessities to live in it!
After install, it’s been cold and dreary so no use for backcountry camping with heat yet. Every once in a while I’ll think to turn it on for a sec to get any stagnant moist air out of there and it does the trick (as far as I can tell). Hasn’t leaked, hasn’t flown off to the side of the road so I’d say all good!
Best part about it is exactly what you state. When I put the key in it doesn’t pop it open. Just today I lengthened the screw and put a rubber stopper on it to really cinch the door tight and keep the metal to metal grinding from happening, will see how it works but getting the side panel latches ordered soon for winter.
Does this make me a hipster?
Certified.
Sick spoiler! Where did you get that!
Same! Share the downforce! My toaster needs all the help it can get in the speed department ![]()
I have only seen it one other time on a GFC video on their page. Maybe an older item they used to have since @GainzGFC mentioned it being a V1 and he has a V2 camper I think.
The OG Thayne had an orange wing
Yea that is the one I saw on their page. These are hard to come by I assume?
They don’t make em anymore. Gotta find someone selling it or that has an extra if they had a replacement
Can I have yours if you sell the rig?
what was it made out of aluminum?
If you make one I’m interested!
