I’m looking for suggestions on how to pass solar or Starlink cables thru the exterior of the camper to the interior. I know drilling might be required, but not sure if there is some sort of hatch or port that can be installed to prevent water getting in. Any suggestions are appreciated. Thanks!!!
Using Starlink mini. Today I’m just passing the cable thru the side panel leaving it a bit open. Looking for a more elegant solution and trying to install permanent solar panels on top
I keep putting it off as I consider different items I’d want to route through said hole. Initially I was thinking just starlink, but if I wanted to add solar, that’d change things.
Here is my setup. Since I used Starmount I only needed power. If I add solar I would add another one. GFC told me I could not drill through the roof. Starlink Mount
